A/C Fluttering Noise
MY 2001 5.3L SILVERADO HAS HAD A FLUTTERING NOISE IN THE A/C COMPRESSOR SINCE I'VE HAD IT FOR ABOUT 3 YEARS NOW. IT'S ANNOYING AND HAD ENOUGH OF IT. IT HAPPENS WITH THE A/C ON AND COMPRESSOR CLUTCH ENGAGES. WHAT COULD IT BE? BAD COMPRESSOR? BAD CLUTCH BEARING? I AM REPLACING THE BELT AND BELT TENSIONER FOR THE A/C RIGHT NOW TO GET RID OF A SQUEAL...
  • 3 months later...
:shakehead:
TTT, need help. It sounds like quick chhhhhhhhhhh then goes away. Does the compressor only engage for a few seconds at a time? The interval seems to be every 15-20 seconds or so. Is it a bad compressor or just the clutch or pulley?
TIA
The compressor only engages when the PCM tells it to depending on what all the sensors are telling it. That noise you are hearing is a normal A/C compressor noise that happens when the clutch is engaged.
thats a normal sound of freon running through the AC system. If youre getting that and the compressor runs only 15-20 sec on off intervals. Then it is cycling and low on freon. You might have a leak.
  • 1 month later...
My 01 yukon 5.3 just started to make a smilar noise but mine is like a chatter. It almost sounds like a fan is rubbing on something. I replaced the tensioner and belt hoping it was a bad bearing in he tensioner but not so lucky. Mine cools fine and this noise only starts when i have the A/C on. I just purchased a clutch kit from GM and will put that on as soon as i find some directions. I will let you know how it goes. Mine s definately not normal operating sound.
mine is so bad it just blew up! started making a very loud sound like the fan blades were hitting something, thought i lost a motor mount, then BAM, she puked her guts out. extended warranties are worth it.
It all depends on how loud the noise is (obviously :eek: ). I had a compressor on my '94 (AC Delco replacement unit) and this one was loud and sounded as bad as the original one. In fact, it gave me enough noise that it could be heard in the cab. I had it changed out again under warranty and this one was quiet.
bbwb
Done a bunch of these the compressor is slugging check out this bull.
Subject:Underhood Rattle Noise Heard on Acceleration (Check A/C System Performance and Compressor Operation) #03-01-38-019A - (09/03/2004)
Models:2003-2004 Cadillac CTS
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
2002-2004 Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe
2002-2004 GMC Denali, Denali XL, Savana, Sierra, Yukon, Yukon XL
2002-2004 Commercial Upfitter Chassis Vehicles
2003-2004 HUMMER H2
with Air Conditioning (A/C)
This bulletin is being revised to update the service procedure and parts information. Please discard Corporate Bulletin Number 03-01-38-019 (Section 01 -- HVAC).
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1548742&pubid=271#ss1-1548742">
Condition
Some customers may comment about an underhood rattle noise heard on acceleration or a sudden loss of A/C system performance.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1548742&pubid=271#ss2-1548742">
Cause
This condition may be caused by liquid slugging of the A/C compressor. This condition may cause an internal failure in the A/C compressor. The serpentine belt tensioner and serpentine belt may also be damaged.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1548742&pubid=271#ss3-1548742">
Correction
Technicians are to check the A/C system performance and compressor operation using the following repair procedure:
  1. <LI type=1>Open the hood and inspect the A/C compressor for damage and to see if the compressor is seized. Verify that the serpentine belt is not damaged or missing. If the A/C compressor is seized, proceed to step 5. <LI type=1>Perform the A/C System Performance test. Refer to the Heating, Ventilation and Air Conditioning (HVAC) section of SI. Correct any performance concerns or refrigerant leaks that are found. <LI type=1>Inspect the vehicle for other possible sources of A/C compressor noise or performance concerns. Refer to Corporate Bulletin Number 01-01-38-013 for more information. <LI type=1>After all other possible sources of A/C compressor noise or performance concerns have been eliminated, only then should the A/C compressor be replaced. <LI type=1>Remove the A/C compressor. Refer to the A/C Compressor Replacement procedure in the HVAC section of SI. <LI type=1>Inspect the transmission cooler lines for damage due to contact from the serpentine belt. Replace the transmission cooler lines if necessary. <LI type=1>Install an inline A/C system filter. Refer to Corporate Bulletin Number 01-01-38-006C for more information about A/C system flushing and filter installation procedures. An A/C system flush is not to be done unless prior authorization is given by the GM Area Service Manager (in Canada, the District Service Manager). <LI type=1>Install an A/C Suction Screen. Refer to Corporate Bulletin Number 01-01-39-003A for more information about A/C suction screen repair recommendations and procedures. <LI type=1>Install a new A/C compressor. Refer to the Compressor Replacement procedure in the HVAC section of SI. <LI type=1>Install a new orifice tube for the front A/C system. Refer to the Expansion (Orifice) Tube Replacement procedure in SI. <LI type=1>If the vehicle is a 2003 model year Chevrolet Express or GMC Savana van, the vehicle may require a new accumulator. Refer to Corporate Bulletin Number 03-01-38-016 for more information. This bulletin refers to an updated design accumulator that may improve the performance of the A/C system. <LI type=1>Install a new serpentine belt tensioner and serpentine belt if they have been damaged due to A/C system slugging or an A/C compressor seizure. The serpentine belt tensioner may have broken stop tabs and/or a missing front cap.
  2. Verify proper operation of the A/C system.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1548742&pubid=271#ss4-1548742">
Parts Information
Refer to the GMSPO parts catalog for the latest service replacement compressor part numbers.
Part Number
Description
Qty
89016656 (*A/C Delco Part# 15-10413)
Universal In-Line A/C Filter
Parts are currently available from GMSPO.
*This filter may also be purchased through your local A/C Delco distributor.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1548742&pubid=271#ss5-1548742">
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
D4440
Compressor Assembly - Replace
Use published labor operation time
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
