It's about time
I had 4 dealerships looking for a truck for me and I heard nothing for the past week. Today I drove by a Chevy Auto Mall dealer and found my truck. Just sitting there on the lot waiting for me. It is a '02 White HD CC SB Dura/Alli. I was originally looking for an ext. cab, but the price was right on this CC. I put $200 down on it today and doing the financing and picking it up tomorrow. I was supposed to have a truck last week, but the dealer trade fell through. I am a happy man now that I have one sitting there with a sold sign in it waiting for me to pick it up. I will have picks real soon, and will be asking a few more questions around here.  :D  :D
BTW, while I was sitting there, a '03 2500 non HD pulled up to the service garage. From where I'm sitting, I am d@mn happy to be getting a '02. Just my opinion, but it looks like a F%rd Ranger hood on those things.  :D
Thanks Shaners! Only thing now is I'll have to watch myself and my GF to PUT IN DIESEL FUEL and not 87 octane!  :D  :D
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
