Power Steering Fluid LOW!!!!
Just wanted to know which type of power steering fluid is recommended for a 2002 GMC Sierra 1500 Ext Cab.
Any advise for be greatly appreciated!!!
Just throw the regular ole fluid you see at the auto store, I have a bottle that I use for my wifes Honda and my truck, don't think there is any real difference.
  • 4 months later...
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 874 Guests (See full list)
