Grease zerks
'01 and newer 2500 HD's and 3500's have 11.
2) upper ball joints
2) lower ball joints
2) outer tie rod ends
2) inner tie rod ends
1) pitman arm
2) idler arm
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
