04 Silverado 6.0
Just got the truck a couple of weeks ago. Im looking at doing some stuff to it....exhaust, intake maybe chip. just seeing what u guys think would be the best thing to do first and if anyone has any sound clips with this stuff on it. thanks
Congrats on the new truck!
One of the least expensive mods you can do is a custom tune. Check out http://wait4meperformance.com. Many of us here have wait4me tunes. There are others as well...I'm sure those with other tunes will chime in.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
