Drop Shakels
Has anyone put these on their truck? If so, have you have problems with the shakels making noise?
I was having a loud rubbing noise coming from the shakels. It was heard getting in and out of the truck and driving over any bumps. I took it in and the bolts were lubed real good and tighted while the truck was on the ground not on the lift. The noise seems to be gone and I was told the bolts were tightened before while it was on the lift which made them too tight so they made noise.
That is a feasible response. Most suspension tightening should be done with the vehicle on the ground.
--Mike
ooops. then i guess i need to loosen my shackles, lift the truck and then tighten them on the ground. I did mine in the air and they are doing just fine....
