Need Help Locating a Factory XM Harness
Ok so I bought a XM unit off of ebay and thought it would be easy to go down to the dealership and order the harness that goes from the XM unit to the back of the radio. Apparently the only harness that the dealership could find is one that costs 784.00. Its a huge harness and includes other things that I do not need.
I found the part number for the bracket which is 15189091 and lists for $14.88
What I need is the part number for the harness that comes with that over priced XM kit. Can anyone help me out?
Thanks!
the whole xm kit is part# 12498768. you should be able to call the dealer and get them to give you a breakdown of the parts in the kit. fyi: here is what i found at the avalanche site:
XM Retrofit Kit: P/N: 12498768
XM Antennas..P/N:
'03: 15174788
'04: 15205583
XM parts, per Blacktrail_Av on 10-31-05:
Cable, digital radio receiver: 15172751
Cable, digital radio antenna (inline conn to antenna): 15205597
Receiver, digital radio, `must get from seperate souce. Part#: 22692861
Receiver, digital radio, kit 2007. Part# 178011509 Common accy item.
Bolt/screw, hwa for receiver bracket: 11516618 (needs 2)
Bracket, digital receiver: 15189091
Cable, digital radio antenna: 15190807
Cable, digital radio antenna (rcvr to inline conn): 15205596.
Ant, digital radio (40mm high low profile antenna): 15174788
Ant,digital radio (35mm high low profile antenna):15205583
From CAFCNA: Willyt.
Ant, digital Radio and OnStar (Digital) combo "Shark Fin": 15194280 List $147.27 whosale $110.45
Cable, For dual service "sharkfin" antenna: #15292901 List $60.66 whosale $42.46.
  • 3 weeks later...
If you're just trying to install a generic XM receiver to your factory radio, you should look at getting the harness from P.I.E. at www.pie.net.
    Brandon 29
    Brandon 29
  • Who's Online   0 Members, 0 Anonymous, 367 Guests (See full list)
