Diff And Transfer Case Oil ?
trailrider325
what front and rear diff fluid do i need to use and how much goes in each and the transfer case what fluid and how much does the transfer case need after i change it. i have 50,000 mile's and how often should i change these fluid's
I changed mine on my 02 right away when I bought it with 33k miles. I used Mobil 1 synthetic 75w90 in both front and rear differentials. 2 quarts front and just under 4 rear. I used Mobil 1 synthetic transmission fluid in the Transfer Case. 2 quarts. Transfer case does not need the blue autotrak stuff unless it has the auto 4x4 feature. I had a Yukon with that.
That's exactly what I did. Mobil 1 gear oil in the front and rear and Mobil 1 synthetic trans fluid in the transfer case. Smooth as lotion and it loves temperature extremes.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
