Bose Stereo Questions And Upfiring Vs. Downfiring
Nova
I just bought an 04 Silverado extended cab with the Bose system, equipped with OnStar, steering wheel controls, ect. I am going to have to do something with the stereo, and I just see this being a huge snowball effect IE: add subs, speakers won't keep up. Change speakers, they'll be under powered, ect. So I want to know what I am dealing with before I even start buying. I know from my time working at a GM dealer, that most vehicles have 8 ohms speakers from the factory, is this the case with Bose? I am still toying with the idea of retaining the factory head unit and swapping in aftermarket speakers and adding a sub or two.
In all likelyhood, I am going to end up swapping everything out and running entirely new wiring while leaving the factory wiring intact (just in case). I know there are harnesses that allow for an aftermarket deck while retaining the chimes, steering wheel volume controls, ect. Is this necessary for any reason? If it won't cause me any sort of electrical issues at all, I'd just as soon go without.
I know a fair bit about stereos, but have never really seen or heard of downfiring until I started visiting these forums. It seems like the majority of downfire systems I have found are in the NBS GM trucks. Is there a particular advantage to this, or is it just personal preferance?
do a search there are lots of ways to go. i added downfiring subs in the back and the bose sounds great to me. it just depends how lound you really want it. once you add some subs the bose sounds 100% better for a lot less than a whole new system.
Almost all aftermarket speakers are 4Ohm. I'm surprised to hear the factory were 8Ohm.
And as for the Bose speakers, I can only assume they are 4Ohm as that is the norm when it come to higher performance speakers.
You need to get a special module to retain your OnStar when replacing the factory radio.
Visit crutchfield and use the outfit my car option, and it will find the necessary hardware for you.
Lots of Bose, or as I call it Blose, speakers are not what you would call normal ohm ratings. Generally anything driven by the headunit is 4 ohms (normal). Anything that is amplified using the tiny stock amps is 1.5 or 2 ohms. I cannot speak to what blose has done in the trucks yet as I have had the truck about 2 weeks and I am still in the process of buying a new system, however I do know for fact that this is the case in the Corvette with blose systems. Pull out the ol multimeter and check it out.
I do believe that blose does this for 2 reasons, one is that you cannot just replace their crap paper speakers with a better performing model as the power output of the tiny blose amp will not drive them, and two (linked to one) is that if you blow something up in the system, you are forced to either replace it using outrageously priced blose factory replacements, or rip the whole system out.
Just my experience with GM systems, and I have changed a few.
G'luck
Fej
After more extensive searching, it appears that you may be correct with regards to the Bose speakers being 2 ohm. I guess that pretty much ruins any possibility of simply adding speakers to the stock system. I guess the only other possibility is to wire in a 4 channel amp for the speakers and a mono amp for the sub. But I think at this point I may go completely aftermarket. I've got Boston 6.5" and a Concept 275 RMS mono amp that I plan on pulling out of my car prior to selling it, so I have a bit of a head start. Looking at probably going with a single 10" or 12" DVC sub, an amp for the highs, some new 4x6's and a decent head unit. May look into putting in some new tweeters and powering them off the head unit. Not sure about this though, as GM aimed the factory tweeters in a pretty useless direction, so I may have to modify.
I would agree though as far as the Bose being sub par. It really doesn't sound terrible for a factory sound system, probably good for the average Joe. But playing any song with decent bass will have the woofer bottoming out at half volume and sounding terrible. Not to mention, being that the hearing in my left ear is only at about 10%, I like my systems loud and clear.
The Bose speakers in your truck are 2 ohms. Kenwood makes a pair of two ohm components and coax speakers under their excelon series.
PAC makes an adaptor that "retains" your chime and provides you with a constant accessory (constant accessory is what enables you to turn the key off and still have your radio play until a door is opened in your truck). The reason I put quotation marks around "retains" is because it doesn't retain your original factory chime, the PAC adaptor has a black box connected to it that outouts a chime. IMHO, it sounds like crap. Just bury it deep in your dash and it sounds somewhat acceptable. You just get used to it after a while.
PAC also makes an adaptor that allows you to utilize your factory steering controls. Just make sure your aftermarket deck has a steering wheel input for the data wire coming out of the PAC adaptor.
Bose systems sound fine and all, but good luck with your bose highs trying to keep up with your aftermarket sub.
Bose hardly makes highs .. in fact the vast majority of there stuff has two big holes in its output, lower midrange (260-500ish) and about 12k and up. Most blose systems do not have a sub, nor a tweeter ,, just two small drivers trying hard to fill in what they can.
IMO go aftermarket if you are going that far in, even a modest speaker upgrade using blose power really is not that much of a difference.
G'luck
Fej
  • 2 months later...
FINALLY! Nice to see someone with the same year truck with the same problem. Ive been reading different forums for over a year trying to come up with solutions. I've been looking at the Pioneer DEH-9800BT
http://www.crutchfield.com/S-mbin197zoSj/c...=130DEHP980#Tab
Now I am no audio expert. This head unit has all the features I'd want. Well except HD radio. Anyway, according to the people at Best Buy they suggest swapping the head unit out first, then go with the speakers after you hear what it sounds like. Now, I will say that I don't take what people from Best Buy say as the Gospel, I'm hoping someone here can confirm. With this radio, I would have to get the steering controls module, and the module for the chimes and whatnot. I'm debating if I even need the one for the OnStar anymore seen as how I think by the end of the year if you dont have the digital version, it won't work any longer. I dont use it anyway. Not sure what to go with for speakers yet. Hopefully some of this helps out...maybe
The 9800BT is a great HU. I had it in my OBS Tahoe - it also had polk speakers all around, kicker sub/amp, etc. It sounded great and had tons of the features. The bluetooth is what sold me on it, and it worked pretty darn well.
I actually started with the HU, sub/amp only. Unfortunately the stock speakers only lasted a few minutes before I was on my way back to the store to pickup all new speakers. :banghead:
Of course, my old Tahoe didn't have to worry about door chimes, onstar, or steering wheel controls. But just make sure you get the wiring harness specifically for that model (if they have one). The standard pioneer harness I had wouldn't work with the 9800bt and it had to be hard wired.
And yes, the Bose "premium" system in my Denali is about as average as it gets. Fortunately it does have components in the front and a "sub" in the back. Honestly, the weakest link is the HU that doesn't properly drive enough power to the sub when it's needed (poor EQ adjustment). I hooked up my notebook w/ an audigy sound card to the aux inputs on my rear dvd entertainment system, and with some EQ tweaking, it actually sounded pretty darn good. :rolleyes:
The bose headunit does not supply power to any speakers. The stock bose head unit is a source unit and that is it. A vast majority of the signal processing and powering is done in the amp.
All crap, regardless.
Aftermarket is the way to go. A far as upfiring, downfiring, front firing back firing...it is MOSTLY user preference and whatever the space allows for. There is a difference between each installation, but it is minimal unless you are using super high class equipment. Also i am assuming you are gonna go sealed so that makes the difference even less. The most important thing is just make sure the sub will not be coming into contact with any surface while it is at peak excursion.
As far as the adapter is concerned...totally not necessary or needed unless you like hearing your speakers chime when you open the door. Your airbags are NOT routed through them like alot of salespeople like to lie about. The only adapter you may want to get is the steering wheel control module.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 505 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
