8.1l Pinging Or Detonating Or Other?
MEGA14
I have a 2002 Silverado 3500 with an 8.1l/Allison 1000 and about 180k kilometres .
about 40k kilometres ago , the engine started making a sound ( like that little ball in a spray can , only a bunch of them ) while under light or heavy acceleration.
I've been using Sunoco 94 Octane for almost 2 years and my throttle body is very clean so I wonder what it is.
Also , I recently poured 2 bottles of Pennzoil FI cleaner in 2 seperate tanks and although it initially eliminated about 80% of the noise , it has since come back.
Any thoughts/advice would be appreciated.
This is your answer!
Also change gas brands for a little bit.
Yeah , I have read a bit about that and I really should give it a try if I can find it. Napa , here in Canada or at least Toronto doesn't carry Deep Creep , they have the liquid only .
Thanks for pic of the product .
Sunoco has the highest octane at 94 but I could drop to 91 I guess with Shell .
I have a box of 8.1 sitting in my shop (detonation problem) I don't know the exact specifics, but it ended up burning two a pinkie sizednotch out of two of the the valves, which sent a # of pieces of crap down in to the cylinder and ended up screwing the piston and beating the head. you might want to consider A) checking fro GM programming recalls or B) spend a $100 and give hour at gm an hour to do a diagnosis then at least you will know if it is a programming fault.
As Norseman said, Deep Creep is a great product. I would also recommend Techron by Chevron. Run it at 1 oz per gallon for one full tank. If this and/or the Deep Creep do not clear up the pinging, you have a anti knock sensor issue.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
