Headlight Problem
sammykitch
I have a 1998 Silverado. When I turn on my headlights the DRL indicator light stays on and I have no High beams. What could be the problem? I just bought the truck and would like high beams. I also tried turning on the headlight switch with the engine off and all the lights except the headlights came on. Could the switch be the problem.
You may be having a relay problem. Check under the hood in your fuse box. There are relays in there as well. You may have a bad relay for your headlights.
good luck
I had weird problems like that. The dealership replaced the BCM and that took care of it. I'm not sure how you could test that on your own though.
Hello, I have a 04 escalade ext that is a thieft recovery and the headlight wiring was cut off, could you give me the connector pinout of the headlight connector?
Thanks
Chris
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 686 Guests (See full list)
