1995 Gmc Yukon Tring To Get 20 Mpg.....
Posted some of this in another post but figured more people might read it here.
Ok a wait4me tune anyone got one of these for gas mileage? How about a cold air intake? My 1995 yukon with 5.7L 3:73 gets about 12 mpg on 87 octane........... I am shoting for upper teens in mpg (would love to get 20 mpg) Is this imposible? What other mods would help me achive this. Also i tow sometimes so would a hand held programer be better for me? I could just buy one of these custom deals and keep the stock computer. I would switch to a higer octane if the gains out weigh the cost. With gas over $3.00 a gallon..... even though I love it, its do or die for this truck. Any help would be great.
I don't think its possible, at some point the engine will be running really d**n lean (which would cause problems in the long run)... I mean I guess you could try smaller injectors... just doesn't sound like a good idea to me.
My 2005 6L gets 15-16 on summer blends and 12-14 on winter ones. 10 years more and I'm not doing that much better (I don't think the 300ml of displacement is that big of a difference).
Get your self a 454 in there. Either it will have so much power that you will get close to your 20 mpg goal.....or it will drink so much gas that what you were getting without it will seem awesome.
in all honesty though..it will be hard. 18.something is the best I have ever heard of. Its a big vehicle. Switching to higher octane on a stock engine that is not programmed for it will do you no good as octane is designed NOT to burn. Thats why you need more octane if you have a high compression or if you have forced induction. Its to stop pre-ignition (detonation) because you can only compress the fuel so much before it just self ignites. Octane is a ratio of how much you can compress the fuel before this happens.
If you use high octane in a vehicle that isn't designed to burn it it will not completely burn and cause deposits on the valves, pistons and combustion chambers and these too will cause pre-ignition as they soak up fuel and ignite after the plug fires and the piston is not in the right position any more.
tune will help...wait4me is a good one from what I have read. get you about 2-3 MPG.
*copper electrode plugs and some good wires.
*an intake may help some.
*maybe an MSD or similar multi spark ignition. get a good distributor (if your truck has one, cant remember if 95 do or not).
*if your running aggressive thread tires, change them out for a milder street profile.
*under drive pulleys.
*If you have a clutch type fan rather than an electric unit, change it, it will give you about 1-2 mpg more and about 15-20hp.
*switch to synthetic oil would be an option but on a 95 I wouldn't as you will probably get a lot of leaks. however there is a very good possibility you have a sludge buildup so a hot oil flush at your local GM dealer wouldn't hurt anything.
*get your fuel system cleaned too.
*I run lucas fuel system treatment every other tank or so and that seems to improve mileage.
Thats about all I can think of at 10pm. Hope it helps some.
My Wait4me tune has added about 1 MPG to my daily commuting mileage. I'm not complaining; it'll still pay for itself in about a year, and I don't mind that it goes faster if I put my foot in it. I checked before/after 0-60 times and it went .43 seconds quicker with the new tune, with no driveability issues.
You're not going to find 5-6 MPG in your truck, I'm afraid.
17 or 18 would make me very happy
You could also change those 3.73 rear end gears out to a better set of highway gears, BUT you will lose some low end performance and towing ability in the process. If you aren't towing anything really heavy it might be worth it.
Good, well thought out suggestions Nytemare!
thanks bro...not bad if I do say so my self for being awake for 17hrs...LOL
Yeah good sugestions! Well the ring gear would probably be good but i just rebuilt mine about 200 miles ago!
I'll problay get the tune, cai, and the electric fan..........I did that mod on my 1990 mustang gt and the results were great. About 10-15 hp on it
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
    • New engines will still be using DEF. You just won't have the limp modes occurring when you run out of DEF now.
    • I am not a NOCO fan for a charger I would leave on a battery 24/7. The reason is, it doesn't really float. It waits until the battery drops to a certain voltage and then charges it back up to 14V. It's better than no charger I guess.
    • I would never do anything but lithium.   If the vehicle is stored, just turn the disconnect off. My batteries are completely disconnected form everything in the trailer when my disconnect is off. Trailers don't always come that way as some still keep the CO/LPG monitor on. When mine is off...it is off.   As far as storage temps, LiFePO4 are good down to -20°C. I would store them in a heated place if it goes below that. You can also get heating mats with a thermostat if power is available.   The way the heaters work, if it's below 0°C, if a charge comes in, it is directed entirely to the heater until the battery gets above 0°C and then it allows the charge to go to the battery.   For my Android tablet I use as a display, I can move it inside my house if I was ever in an area that got super cold.
