Ground Force Lowering Kit For Tahoe/suburban
The reason I ask if anyone has used this is I want to see what the sway bar spacers look like. So many people are making lowering kits, and they are all different. I have the 3" rear lowering springs, shock relocation brackets, and the front torsion keys. DJM has a trailing arm relocating kit that has a sway bar kit in it, but they want you to move the sway bar 2" to the passengers side.... don't know if I want to do that. Belltech sells there kits with nothing for the sway bar, or the trailing arm. Hard to know which way is going to give you the best ride.
It seems that once you lower it, you have 2 problems.
(1). Your trailing arms are at an angle instead of being straight... the DJM kit takes care of that..... (don't know if that really matters.)
(2). The sway bar that attaches to the axle housing, and the frame will be at an angle once you lower it... (don't know if that really matters.)
I have an 04 Tahoe, with 22" wheels. I need to get that gap a little smaller.
Here's a picture of it stock ride height.
    hotfish
    hotfish
  • Who's Online   7 Members, 0 Anonymous, 597 Guests (See full list)
