how would a 315/75/16 work out on stock suspension of a 07 2500HD 4x4? or would they even fit? i found some that seem to be a good deal, might pick them up if they'll fit.
ok ill check into it, i have the 07 classic, i know the rear will fit but its looking like i might have rubbing problems in the front. i might have to crank the torsion bars up some to get a little extra room
You will need to crank the bars tite/ trim the frt bumper/ trim the fender liners/ and cut a wedge from the bottom rear of the frt fender...then you will have very little rubbing without mudflaps.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
