Fuse Location?
Well I bought some new bulbs for my daytime running lamps because neither of them worked. I installed the new bulbs and I still don't have any running lights. That leads me to believe its a fuse, but I can't figure ouyt where it is at... Does anybody know what the abbreviation for it may be, or where the fuse is at?
DAVE.........Gotta remember on SOME GMs the drls will come on
when put into gear.
Can't remember about the drls in my 01. Thought the DRL fuse was
in the interior fuse panel on the side of the dash. Should be marked
DRL.........................
Yep, that was the problem. I forgot they don't come on until it is in gear... Its kinda hard to check that when your working by yourself though...
They should be on in neutral if you need to check in the future. I know I had the same challenge one time myself.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,231 Guests (See full list)
