Shopkey
I got access to ShopKey5 today so if any of you guys need help, diagrams, tsbs, or whatever let me know and I'll see if its on there. I know some other people have shopkey or similar but I figured another couldnt hurt!
Before I go to the stealership for warranty work, I want to be prepared, especially since our dealership isn't known for having the "sharpest tools in the shed." Anyway, I think these TSB's are relevant for my GMT-900 ('07 Silverado NBS) and my issues. Would you mind checking what's in these TSB's? If you need any other information please let me know. I really appreciate your help.
07033B FEB 07 Campaign - BCM Reprogramming for Battery Drain
02-06-03-008B APR 07 Charging System - Low Voltage Display/Low/Dead Battery
07-08-50-010 MAY 07 Seats - Squeak Or Creak On Driver Side
Sorry for the delayed response, I've been working 17 hour days the last 4 days.
07033B FEB 07 Campaign - BCM Reprogramming for Battery Drain - Essentially says that if you leave the ignition in on without the engine on and have the stereo on or another accesory The battery will drain to the point where the vehicle wont start. They will reprogram you BCM and test the battery, should take .4 to change bcm and .6 to "Add: Test & Replace Battery"
02-06-03-008B APR 07 Charging System - Low Voltage Display/Low/Dead Battery - Just says what will happen if you are using more power than your alternator is producing at idle... Basic knowledge kinda stuff.
07-08-50-010 MAY 07 Seats - Squeak Or Creak On Driver Side - Noise coming from lower seat frame, spring may be causing hard contact with frame. Replace the lower seat frame. Covered under warranty. No labor codes.
Hope this helps,
Jon
I heard there is a TSB, but im not sure. On my fathers 2006 GMC Sierra 2500HD Crew Cab, his passenger seat has a squeak starting out and stopping. I know all the crew cabs have the problem, wondering if theres a TSB so I can get a new seat or even a fix out of GM. I know there is a TSB on the ticking at idle, just wondering if theres a fix in there, I doubt it, but since it has less then a year left on warranty, just like to see what all I can get taken care of. Also, same truck has a squeak or creak taht is constant in the suspension. Just wondering if theres a TSB for that possibly too.
Hope this helps,
Jon
That definitely helps. Thank you VERY much. :rolleyes:
Ticking - Only for Diesels, and It says its just something that diesels do.
Seat - Nothing about a squeak but theres a tsb about the hours for cushion replacement, like there was in the other trukcs tsb.
Squeaking Suspension - Nothing for the front but a "popping" noise that has to do with washers on the crossmembers. If its rear your talking aobut it just mentions the old squeaky leafspring fix. (Jack it up, pressure wash the springs, grease them).
Hello!
Do you still have access to this information? If so, can you see if there is any publication covering power seat memory loss when using the #1 & #2 keyless remotes? My '03 1500HD gets kinda crazy when the two different remotes are used.
Thanks for having this info. available.
Respectfully,
Jeff
Hello!
Respectfully,
Jeff
Maybe this will help?
Theres also one about getting your software calibrated witht he update as of april 18, 05.
