Powering Up Electric Brake Controller
fdpirate24
I installed my electric brake controller under the dash and purchased a 40amp fuse for the under hood fuse box. Where do I find the wires to connect to post 2 on the underhood fuse box and what size nut do I use on the post? By the way my trailer has a battery for emergency break away brakes.
I have a 2007 new body style 2500HD and don't have a wiring harness or information on how to install a trailer brake. The dealer says that the harness does not come with the new body style trucks. Help!!!
Thanks,
Curly
Thanks,
Curly
I found the wiring harness already wired under the dash next to the emergency brake and vehicle diagnostics plug. I wired my controller, but understand that you not only need a 40 amp fuse in the under hood fuse panel for stud #2, need to locate a wire to power up the controller and to charge your trailer breakaway emergency brake system. Those wires are supposed to be near the brake booster under the hood, and need to be secured to stud #2 where you install the fuse. I was looking for information on where to locate the under hood wires and what size nut goes onto stud #2.
Thanks,
Curly
The +12V wire for the brake controller is located between the under hood fuse box and the left fender. You should see a red wire with black stripe taped to the wire harness that passes between the fender and the under hood fuse box. I think the stud #2 nut may be an 8mm because 5/16in does not fit.
