Oil Pressure -- Can U Change It?
so when i start my truck and drive it at first it feels really torquey?! lol ... but after i drive it for a while and it gets up to operating temp for a while it seems like it looses a little ... and my oil pressure drops just a little ... is there something i can do to keep that strong start up feeling it has?
Has nothing to do with oil pressure. It is the engine temp. The truck is running richer(More fuel, more power)or in a closed loop mode to bring the engine up to operating temp. What you are probably wanting is a lower thermostat(and a tune).
as for the oil pressure dropping, its because the oil is a bit thinner at operating temp.
Actually its open loop. But you are right it runs richer until the O2 sensor warms up before it goes into close loop and leans up the mix.
ATF temp might be a factor as well. Perhaps your engine is sucking hot air from the engine compartment too?
i have a tune ... can i get a new thermostat? if so where and what temp would i get? it's an 01 1500 5.3L
160 degree. You local parts store should carry them. If not look at some of the aftermarket performance suppliers.
I did notice the guy was in wisconsin. It might be worth checking the temp to see if he has a winter thermostat instead of a regular one. In that case reducing to a regular might be fine.
I had a 160 in my old truck when I lived up north and its really hard to defrost and heat your hands when its in the negatives and your truck only has 160 degree water to work with.
Changing the thermostat will throw the computer off by it changing the mixture for a cold engine mileage will suffer. I believe that the factory thermostat is 195.
bbwb
bbwb
i already get 17 hwy BEST so i better not mess with mileage at all LOL
bbwb
I do not have a catalog avail with me right now but I beleive the OE stat is a 185.
bbwb
Yeah, and you will be the same guy who comes back here complaining that he is only getting 10-12 mpg afterwards. Leave the stock thermostat in place, there area numerous reason's why it is set to 195.
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 591 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
