Roughcountry Leveling Kit Installed.
After seeing 96Vette's post I ordered the kit and used his tip to install it and it was pretty easy.(thanks) took probably an hour. now truck is sittin level and lookin much better. also added tint and a grille overlay the other day. The first two are before and the last two are after
beforeafter002-1.jpg">
beforeafter003.jpg">
beforeafter005.jpg">
beforeafter006.jpg">
I just ordered the 1.5" kit,Can't wait to get it installed,I hate the front-end sitting so low!
"remove the wheels take the 2 bolts out of the bottom of the struts loosen the sway bar nut all the way to the top pushed down on the "A" arms and slid the spacer in, hardest part was lining the holes up. Both sides from start to finsh took me 45 minutes to a hour. air tools are a great thing. The directions said to break the upper ball joints loose and the tierod ends, didnt have to do that. "
I haven't gotten an alignment yet. watching the tires to see if they wear differently and will if they do.
