Help!02 Suburban
ThorsHD
there is a block about 6in square with 4 steel lines going into it. It has an electiric motor and it keeps running. I crawled undenieth and unpluged the motor and now the traction control light and abs light are on.
I drove it around and it all works fine, except that the traction control and ABS lights are on. I'll try and plug it back in the morning. anybody have any input? You get to it from under the burb directly below the driver seat. I did check the brake fluid and it is full....
that noise you here is your ABS motor, the relay inside of it is shorted and the motor stays running,
i beleive you will need to replace the abs motor/module assembly, but its a common problem, ask around for more details... i just know its alot of money for the part :rolleyes:
The part is an EBCM(Electronic Brake Control Module), i would just shop around, if you get it from
the dealer you'll probably pay like $700(give or take) , just shop around online, there's deals everywhere that are
better than a dealer...
  • 3 weeks later...
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,189 Guests (See full list)
