Husky Mud Flaps?
has anyone installed the new NBS Husky mud flaps yet? if so I would love to see some pics. I like the fact that they are plain black with no emblems.
Check these out:
http://www.luvernetruck.com/Product_Line/S...ash_guards.html
I got the 12" x 20" for the front ad the 12" x 23" for the rear. They are nice.
Fronts mount using existing holes, rears use clamps (no-drill install).
How much for the luverne??
I don't recall exactly, but I think the set of four was around $100-120 or so. Not cheap, but you get what you pay for.
I did put them on my truck, unfortuntly I did have to remove the rear tires to drill some holes. Other than that easy to put on.
Think I paid $45-$50. Like the look of the Luvernes better.
Not the best pic, to many shadows.
Vmax, I know I've probably asked before, but those sit flat behind the fenders? In other words, do they wrap up along the body or no? I want to avoid something that wraps due to the paint rubbing concern as well as the possibility for corrosion with the salt up here in the midwest. Thanks
Here is a picture of the Huskey mud flap. I like the all black look and they were easy to install. They come with a clear film to protect the paint. I replaced the screws that came with them with bolts and nuts. Got mine from Cabela`s
Nope, they do not wrap around and do not touch any paint other than on the inside lip of the flange. Now worries there.
Here are some pics, sorry for it being dirty and poor photography.
Sweet, any ways to get some close-up pictures? How do the fronts mount up with those wheel liners already in place? I never got flaps/guards on Big Blue, but I think Maxine should have a set.
Fronts use existing holes in fender lip, rears use clamps. (no holes in rear lip).
Good deal, but do they go under the wheel well liner and against the metal or on top? I have to think under, but I'm not looking at my truck now so I can't picture how it comes together. Any way to get some pics of your ride with them on, perhaps from behind and also the mounting of each? I know I'm being a pita, but I want flaps to keep the chips down, but don't want water/salt getting trapped against the paint like my combo flares/boards did on my old Jimmy.
Scroll up and look at post #9, I edited it with pics while you were requesting them. What can I say? I am psychic. I didn't get a pic of the mounting though and my camera's card is full. But the front ones mount over the top of the liner. Just buy the d**n things, you will like them. :)
You've got me pretty much sold on them. I'm getting the GM steps as well(Friday or Saturday hopefully), so I can see how the stainless on the guards will bring it together. So no drill on the rears, and the fronts appear as if you'd just back the existing hex headed screws out that go into the fender liner, correct? No drilling? Being in the midwest, I'm just concerned about drilling and all that could yield a spot for corrosion.
VMax, what size are your wheels? I have 20s and am not sure mud flaps will work for the fronts because there doesn't seem to be much clearance.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
