Giving tom a run for his money
Sorry Tom, I think I've almost got you on the blindingly brilliant beauty of the red trucks:
Notice the reflection of the parents POS chrylsler minivan on the side :thumbs:
It was nice out yesterday, about 60 degrees when I left work so what choice did I have, but to wash my truck.  It was very depressing though seeing all the scratches, dents, and dingers in it from winters abuse.
What scratches?  Lookin good Jon!  Are sure its not just one of your photoshop jobs??   :(
How's the BL doing?  What are you going to do about the tow hooks and hitch receiver?  Step bars soon?
I opened my buddys tailgate that has a BL last week and the the whole bed rocked.   :thumbs:
His tailgate is a little heavy because of his spray liner, but still..  Does your do that?
No problems w/ the bodylift at all, the bed and cab are solid.  You can grab the bed rail and yank out and it'll rock the whole truck just like it did before the bodylift.  I haven't put the tow hooks or hitch back on yet, they are on the to do list, as is buying the PIAA air dam and a HPPIII.  No problems w/ the tailgate, I have a spray on bedliner, and it still operates like it should.  Perhaps your buddys got a few screws loose :thumbs:
The scratches are small, it looks like some careless people have been letting there zipper rub on the bed while reaching in (not me this time, I kill people who do that).
Step bars are on the list to buy as well, just need some $$$
I haven't put the tow hooks or hitch back on yet, they are on the to do list, as is buying the PIAA air dam and a HPPIII.  No problems w/ the tailgate, I have a spray on bedliner, and it still operates like it should.  Perhaps your buddys got a few screws loose :(
Maybe..  If it rocked forward any more it would probably hit the back of the cab..   :thumbs:
I don't think the PIAA airdam will cover the frame w/out a little saws-all action..  Let us know how it works out.
Looks good Jon.  :thumbs:
Speaking of HPP III's, (or lack of...) how has the bigger tires affected your breaking?  I was thinking Ryan had some minor problems with breaking/ABS after his 285's but before he got his HPP III.
No problems braking at all, actually the truck is a lot nicer to drive w/ the lift.  These tires are a billion times better than any I've had before, the traction is amazing, they've yet to break free in the rain under hard acceleration.
hey jon how come you cant brake free your tires in rain? i always seem to be able to in rain...P.S.  your truck looks really good. lift did wonders to the aparence, i couldnt believe the difference in look and meanness after i put mine on  :thumbs:
I have 285 on mine and I don't have a hpp III.  I didn't notice any problems with braking or the abs, in fact, it drives a whole lot better with these tires then what it came with.  I don't plan on getting a hpp III until I get my suspension lift cause I will prolly regear the truck.    :(
I dunno, my old wranglers weren't the greatest in the rain, they were always slipping and sliding, these just stay firmly planted which is a good thing.  This morning it was really wet out and on the way to work there's a turn where I have to gun it and normally the tires just spin and the truck slides, but I gunned it today and the truck went perfectly, I kept an eye on the speedo and it didn't jump at all (aside from normal acceleration).
One thing I have noticed is cruddy mpg's on this last tank.  I don't know why.  I'm hoping it has to do w/ the fact that I've been running on the same tank for about three weeks now and just been doing short 2 mile trips each time.
You need to lay off of the gas pedal and you won't have a problem. :thumbs:
lose the flares you'll get close to being as red smooth as us  LOL
I was thinking about it actually, or even painting them red, but the truck just didn't look right w/o them and besides, they keep a lot of rocks from hitting the side.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
