Almost done
akdiesel
Looks great akdiesel, I like that matched flares alot, the whole truck looks sweet.  Really nice pics, love the snow background.  :thumbs:  I would kill for some snow...AK looks so beautiful in all the pics I see, I really want to get up there sometime soon.   :D
Thanks for the reply.  They are calling for snow tomarow here in Anchorage.  Won't last long though.  Summer is just around the corner.  Plenty to do up here in the summer as well as the winter.
I was going to go with black or pewter.  But black is such a pain in the a$$ to keep clean.
This is a great forum.   Lots of helpfull tips.
No problem.  We love to help out fellow gm owners here.  :thumbs: Keep on posting.  :D
