Timing
recently installed a new distributor in a 95 chevy c3500 with a 5.7 engine. One place told me it depended on the GVWR which is 11,000 lbs.
At what degree would the timing be set on an 1995 C3500 , automatic, 2WD, with a GVWR of 11,000lbs.? and what if any wires would need to be disconnected? this also has a throttle body injection.
Thank you!! Any comments on where the EST wire is located? Is this the electronic advance wire loop?
All smallblock TBI engines 88-95 call for "0" deg. engine at operating temp 195F and the EST wire unhooked.
Cant remember but its either under the bus bar cover on the passanger side at the firewall or the PCM in the glove box its a tan/black stripe wire.
THANK YOU AGAIN!!
THANK YOU AGAIN!!
Did you find it? Its been 14 years since i dealt with the 1995 trucks. Too many truck to many years. LOL.
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   2 Members, 0 Anonymous, 823 Guests (See full list)
