Fender Flare
well the other day i hit a dumpster with my 04 silverado and it took a chunk out of the fender flare, i found a replacement on lmc truck that is supposed to be exactly like factory, i have the black textured style, does anyone know how to take the old one off and put the new one one before i go to buy it i would like to know how to do it, if i cant figure it out im just going to take it to a body shop
Not hard at all to change,The flares are on with double-face tape and some push-in retainers,Just remove the retainers around the underside of the flare and then you can pull the flare off of the fender.
ok, sounds pretty simple, thanks for the reply
When i replaced mine with some bushwackers i found that it was MUCH easier to remove the old ones using a heat gun. The double sided tape was on there real good and a little heat made them come right off.
