Any Discount Tricks To Resubscribe To Xm?
my 3 month trial ends tomorrow..............i feel $12.95 is to much to pay per month.
are there any discount codes for getting Satellite at a cheaper rate?
i found last time that if it allow it to expire they will call you in 2 months and offer a year at $77. that is what i did the last 2 vehicles, i usually swap every year so its been handy!! i am not sure what they do after that year expires.
yeah they did that with me too. I let it expire and they sent me an offer through the mail which was also $77.00 for a whole year.
Call them and tell them that you want to resubscribe for a few years. When they tell you the price, tell them nevermind. Either they will do with you like they did with me, and give you a lower rate, or they will insist that that is the price you have to pay. Even if they don't keep you, you will probably get the 77 offer in the mail, and can get it for that lowered rate.
I just called XM last month to tell them I wanted to cancel because the quality sucks and I rarely listen to it. Then they quickly offered the half-off discount for a year, so I figured, why not? :cheers: If they don't offer that next year, it's gone.
I have everyone in my family on my plan.... that way I pay 12.95, but all my family pays 6.95 each or something close to that. They are all over the country too.... much cheaper that way.
  • 1 month later...
ewwww
i HATE my xm radio
the stations blow so bad
it's all classical and latin and jazz
i have 4 stations programmed into the system, and i barely listen to any of them
BOOOOO TO XM
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
