New Guy
crush71
Just traded my 01 SS Camaro for a black on black 07 NBS crew cab 4x4 Lt2 1500 with max tow pkg. I thought I might miss the Camaro but I absolutely love my truck. This is the first truck Ive had in 16 yrs and look forward to assistance from this forum.
Hey! Welcome to the Jungle.
Welcome!!
Those Camaro SS's are nice cars and I know I'd miss it as a nice toy,but you'll love your truck!!
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
