For Sale Power Heated Mirrors
I am selling my power heated mirrors from my 2003 Silverado 1500HD. The truck is kept in the garage, has 22,000 miles on it, and therefore the mirrors are in great shape. No scuffs on the plastic whatsoever. The mirror glass has a few small, thin surface scratches that do not affect driving whatsoever. I am selling these because I bought a set of 06 towing mirrors.
$79
Pictures
