A Few Questions Please.....
1. I tried to paint the bowtie on my NBS Silverado, the color matched but it came out a little rough. The can started spirting on my so its not looking too good. How much can I expect a Paint and Body shop to charge me to color match my bowtie and fix my muck up? Ive never had anything painted so I dont know what this stuff goes for.
2. I installed a magnaflow dual exhaust system on my truck and its all clamped together. How much should expect to pay to get my exhaust welded?
3. Lastly, where can I find tough up paint? I dont trust the crap at Autozone etc, or should I? Dealers? Online maybe?
I know the quotes will be round about figure, due to different areas of the country. Just looking at an estimate. Thanks for everything.
I really cannot hslp you with the body shop question but can telly that most any real Auto Parts store can get you touch up paint in a small bottle or a spray can. If you are not sure about them, simply take your truck to your dealer and they will likely have a bottle in stock.
Unless your exhaust is leaking, I would be happy to have the clamps. In many cases the welding process burns off the outer rust protection leaving the welded seems vulnerable to rust.
Jameson,
normally its $5 to $10 per weld. I paid $5 for my last truck for each weld. It depends on the shop and how busy they are and whether you are going to take the clamps off yourself. You can get aluminized paint to cover the welds, make sure you sand them clean.
I tried the painted bowtie for mine and didn't like the way it turned out so I put a polished billet one on recently. Figure a minimum of one hour labor (call the body shop for their rates) and possibly a little for materials. figure $50 (which is why I ordered the billet aluminum one for mine) or so.
You can buy touch up paint at the dealer or have the guys who paint your bowtie give you some in a container, take a small sealable container with you and they should fix you up. Here again, a lot depends on the workload and personality of the shop.
Don't assume the dealership touch-up paint is something special. I spent the extra $ buying the touch-up paint at the dealership and it doesn't quite match. The touch-up paint is just a bit lighter.
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 557 Guests (See full list)
    • We've done a bunch of them.  Very common failure.  They don't sell the park position switch separate from the shift control assembly which is stupid, because they ended up selling a switch on some other products like 2016-2019 Malibu, 2018-2019 Traverse, 2019 Blazer, and another car or two as those were having the same issue for years (but these have a console mounted shifter not column mounted).
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
