Jba Performance Center Open House Nov. 17th
brad@JBAHEADERS
JBA is having a 1 year anniversary at the speed shop everyone is welcome - Free Food, and Raffle Prizes November 17th is the day -
edit - DYNO DAY has been switched to the 27th of October - 2 pulls for $45 - call our Performance center to get signed up 858-495-3395 Talk to Travis
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
