6 Disc Cd Radio Knobs
i have a 2004 tahoe with a 6 disc cd player. gm part # 15196055. the volume and station selector knobs/pushbuttons are worn. i purchased new knobs an want to know how to replace them . thanks
I would think that you would be able to pry them off, unless they are held by a screw. anybody else want to chime in?
Im sure that you cant pry them off. The radio needs to be removed and the faceplate also. anybody else have an idea?
my knobs were worn too on my 04 and i took it to the dealer to replace the whole radio but they could not get the new radio programmed. they ended up pulling the knobs and replacing them. just give them a firm tug and they will come off...............
Same problem on our 2004. But what are the part #'s for the two big knobs? They look bad, and since I now know the little parts alone are orderable....I definitely will do so.
So...part numbers?
So...part numbers?
I purchased the knobs / rocker buttons from a company called Specmo. thier # 1-810-744-2940. I paid $ 10.00 for each knob and $ 10.00 for shipping. They had the parts to me in 4 days. If you have the 6 disc cd player the GM part # for the radio is 15196055, which will come in handy when ordering. They say the worn knobs are very common. I still am looking for a reply from someone that can give me some information on how to change them. Id like to be armed with some info before i jump into taking the radio apart.
Ah, okay, they must be the supplier.
I too think they should just pull off, but what do the knobs in person (the new ones) look like they do? There's 2 pieces, the outer rotating one and the inner button...so what does it look like on the back?
The inner knob has two little " L " shaped legs that prevent it from pulling off the radio. It looks to me that i need to squeeze them by wrapping a string around the back of the knob between the radio faceplate and the knob tight enough to depress the legs and then pull it off. I will try to get going on this sat or sun and let you know how i made out
Yeah, it's hard to tell without ever having seen the back of the knobs, etc., so hopefully it works easily for you and then we'll all know.
Are the things you got just the center "faces" or those AND the outside spinning ribbed part?
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
