Powermaster 200 Amp Alternator Chevy 48203 (new)
Twodogs
Barely used PowerMaster 200 Amp alternator model no. 48203. Alternator was installed and run approxiamately 500 miles then removed to install in another vehicle which was sold before installation was completed. It is in perfect condition and ready to install. These are awesome alternators and sell for $360 - $400+. 125 AMPS at idle and 200 AMPS at speed (Performance sheet from PowerMaster shows 253 AMPS at 6000 rpm). It just won't fit any vehicles I have as of now or it would already be installed and not for sale. It is based on a Delco CS144 / CS 130 frame. Please check your application on PowerMasters website or give them a call at 865-688-5953 before bidding.Thanks for looking and please email any question. $300.00 OBO. USPS money order or Paypal accepted
  • 1 month later...
Still got the PowerMaster alternator. Someone make a reasonable offer and it's yours. I hate to see it just sitting in a box but it I don't have anything it will fit right now. It's as NEW!!
  • 4 weeks later...
  • 4 weeks later...
BUMP- Still available, email me with an offer. It's like new and in perfect condition.
Thanks
  • 4 weeks later...
  • 1 month later...
Alternator is still available- $200.00 + UPS Ground shipping.
Is the alternator still available? Please let me know, I'm very interested. Thanks.
  • 1 month later...
  • 4 months later...
