How To Secure The Edge Evo?
I go the evo in today and to my suprise it was already black! Also I have no clue how to secure it useing the 3m velcro strips. The way the pod is shaped it wont sit in the dash enough the velcro it. I mean its the right pod but I just dont see a way to hold it down besides the little tabs up front. Can anyone help?
Which dash do you have?
Here is a pic of mine installed, I have the SLT (LT) dash. I had to call Edge to get the right Pod since they typically send the standard dash pod.
I used the 2 aluminum angles provided along wih the double-backed tape and 3M Dual-Lock (Velcro). the directions weren't great, but you'll figure it out.
What is that device?
It's a time travel device, all you do is add plutonium and hit 88mph and *poof* you can go anywhere in time you want.... :happysad:
www.edgeproducts.com
[in my best "That thing got a Hemi?" voice]... Swweeeeeett!
I thought that the 3M adhesives supplied were just scotch tape with a 3M sticker on them so I took my automotive grade twin sided 3M and stuck that SOB on there, On the pod there is little plastic tabs inwich the brackets mount too.
I took the two pieces and aligned them the best I could, took the tape off one side, attached it to the pod, lined everything up where I liked it and then pulled the tape from the buttom half (the velcro pieces are still together) and mounted it to the dash. I have the SLT dash as well, so I don't have the tabs. I would think it would be easier with the tabs as they ensure the pod is in the correct position.
