Infinity Basslink
babb
Just wondering if anyone has any expierience with this. Planning on just adding to completely stock stereo and speakers, non bose non onstar 2004 silverado ext cab. Any input or advise appreciated. Thanks
I know what you are talking about, I looked at one on Crutchfield a long time ago when I was adding some bass to my ext. cab. Not sure how much it's gonna cost you, but I wouldn't recommend it. If memory serves, the enclosure isn't big enough to have alot of cubic volume, so I dont think it would be that great. I wound up getting an MTX thunderform enclosure with 2-10"s. That is gonna be more money, and it doesn't come with an amp. But they also make one for that truck that sits on only one side under the rear seat with one 10" sub (MTX).
The least money might be to go with some kind of custom carpeted enclosure for that truck, maybe from subthump.com or you might want to search ebay for one. You most likely could get either a single or dual like that, but you would have to buy a sub for it and an amp, unless you find one already loaded and ready to go.
Had a basslink x in my 2004 Sierra on the factory deck, it sounded good, it added some low end but not thundering bass. Sold the truck an bought a crew s-10. bought an Alpine deck for it and used the basslink temporarily till I got a box for behind the seat. I thought there was a huge difference and hooking it up to the stock deck and the alpine. I am now buying another sierra extended cab and I might be using it if I cant figure something out for behind the seat, but I am definitely putting the alpine deck in although I hate the aftermarket look in the dash. I got mine off ebay for alot better price. For a small amp/sub enclosure "I" think it sounds great.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
