5.3 Litre Diesel?
Hey all, Newbie here.
I have read a lot of the posts prior to buying my 02 Yukon in August especially pertaining to the "Piston Slap" issue. I picked mine up with a 110000 Km.
~Since~ I purchased it in the summer months I thought I had found one that didn't have this problem. Quiet as a mouse.
WRONG!!
Man is it bloody loud, inside of the first minute!!
Any more or new advice on trying to reduce this would be appreciated!
Absolutely freakin' amazing how GM managed to get a diesel to run on regular pump gas!! :crackup:
Dale
I had a 2001 6.0 litre and it had the piston slap I found out by adding a can of injector cleaner carbon reducer to the fuel tank at every oil change just about took it all away, but I added a can when I filled the tank up and then another can on the 2nd fill up then at every oil change there after.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
