Allison 5 Speed To 6 Speed Conversion
greenhog
I have an 01 2500 HD LB7 with a 5 speed allison trans. Internally this trans seems to be the same as the 6 speed except for the clutch combinations it uses to get the 6th gear. Is it possible to convert the 5 speed to a 6 by changing the electronics?
I'd sure be keen to know the answer to that one too. Especially if its not just another gear on top but gives a wider spread of ratios. cheers
From what I have read it is possible. Talk to Mike L. at Inglewood transmissions or Eric at Merchant Auto. Both of these guys have web sites. Mike is in Southern California and Eric is in Michigan. You can check out the Suncoast web site for details as well. LOL
http://www.inglewoodtransmission.com/
http://www.gmdieseltech.com/store2/
http://www.suncoastconverters.com/gmc/gm_products.html
Click on LCT 1000, then click on components. You will see the kit in the upper right.
That's good help, thanks and I have bookmarked those pages for the future. Disappointingly the extra gear is an overdrive and my 8.1 struggles to pull top gear at 60mph (about 1900rpm) as it is with the bigger tires fitted and its slow to kick down back to 3rd when overtaking. So I won't be taking that option. Our roads here are usually narrow and winding and passing opportunities limited. cheers
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
