Vibration On Highway
remy's2000
Hi there...
I have a 2000 GMC sierra 4.8, 5 speed manual 4x4 standard cab short box. The problem I am having is on the highway mainly, I am getting a vibration that I can feel in the shifter. I had the tires checked for balance with no change in the vibration. What is weird is that the vibration happens at lower speeds and higher speed, but become more noticable at higher speed. The vibration intensity comes and goes. My thoughts were maybe the driveshaft needs balanced. I unbolted the driveshaft down by the rearend and rotated it 180 degrees to see if that made a difference, but the vibration is still the same. I am a little puzzled and any advice that you could throw my way would greatly be appreciated.
Thanks!!
Remy
How many miles do you have on the truck? Sounds like it might be the ujoints. Take the driveshaft off and move the joints back and forth. If you feel any binding or feel rough when you move them, they need replacing.
Thanks for your response.
I did pull the driveshaft and both ujoints are tight and one of them is actully new. Is it possible the place that installed the new ujoint bent the driveshaft upon removal of the old one. I know they were beating on the driveshaft to loosen it. It was the ujoint closest to the transmission. I should have known better than to leave it there. That's another story. It has been almost a year since they replaced it. They told me they had trouble getting the old one out. The thing is I don't remember if the vibration started before or after the new u joint was installed, so I can't blame them. I just want to figure out what is causing the vibration. I have learned alot reading other peoples posts here and thought someone else might have had the same problem. Oh and my truck only has 75,000 miles.
Thanks!
Remy
  • 5 months later...
It has been aligned and tracks straight down the road. I did have the problem with the ABS activating and not stopping the truck. And in panic I used the parking brake to stop me. There was a loud bang in the backend but atleast I stopped before getting t-boned. The parking brake still works, but engages all the way to the floor. I can't see how this could cause a vibration, but who knows... I have no play in the front wheel bearings. i am hoping when I get the driveshaft tested for balance it will cure it, but wanted some opinions before I spend the cash on that.
Any thoughts?
Thanks,
Remy
Thanks!
Remy
just a thought. they may have installed the wrong u-joint. I had an older 3/4 ton truck that took 2 different sizes. They installed them ass backwards, and the thing shook the hell out of me.
The problem does sound like a driveshaft vibration. You didn't mention how severe it was but some vibration through the shifter is pretty normal. All manual shift trucks rattle around a bit when the shifter isn't being touched. It's your truck so you should know if it has gotten worse...
A pretty inexpensive fix would be 2 new OEM u-joints and have the driveshaft balanced by a local driveline shop. It can make a world of difference.
thanks for the advice!!
Today I pulled the driveshaft off and installed a new u joint and took it for a quick ride. This seems to have solved the problem, I will try a highway run later this week to see if it has cured the vibration. The u joint I took off seem to have a "flat spot" in it. The vibration was minor, but I try to keep things running smooth.
Thanks again for the comments!!
Remy
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
