Vette Servos
Whats involved in installing these? I would like to do this before I go with increased line pressure, from a tuner etc. What exactly do I have to do to pop them in?
My Drive train has approx 45K miles on it BTW...80 is the max for this swap I believe, someone correct me if I'm wrong.
OK...so with a little searching, and a few coffees, I answered my own question.
http://sethirdgen.org/servo.htm
A quick step by step How-to on the install. Looks to be pretty simple. Its not a total play by play, nor is it servos for dummies...but the backbone info is there.
Heres a site full of 700R4/4l60E goodies.
http://www.4l60-e.com/
I'll probably take a crack at this in the spring, I'll switch all my drive train to RP fluid too at that time.
Edit:
found a better one on gmfullsize, but this mod is only for the 2nd gear. Apparently the 4th is inside the pan or something????
http://www.gmfullsize.com/forum/showthread.php?t=98029
Going from memory the Corvette servo holds the band 18% tighter. The 4th hold billet servo holds the over drive band 40% tighter. I no longer use tow-haul mode to tow my camper, no problems at all towing in OD.
Don
Also gets you in the gear quicker. without increasing line pressure. the piston has a larger surface area, allowing the pressure of the fluid to act on it more...remember, pounds per square inch, more SI=greater force from the same pressure.
this will take the long 1-2 shift away. Makes shifts less sloppy.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
