Replace Headlight Bulbs - 2007 Denali
USCTrojan001
I want to replace the headlight bulb with something brighter. How do I do it? Any special equipment required? The manual only provides direction for replacing tail lights.
Thanks!
  • 3 weeks later...
I want to replace the headlight bulb with something brighter. How do I do it? Any special equipment required? The manual only provides direction for replacing tail lights. The manual says to go to the dealer for replacement.
Thanks!
i havent done just the bulbs on one of those, so im not sure if ou can sneak them out, they just twist out of the lamp so if you can get ur hand in there, great... but i think you have to pull the whole lamp out to get at them... to do that, the bumper has to come off, not all the way but just lowerd down a bit, there are a couple 10 mm bolts that you cant get at without doing it... its pretty easy to do, i can do both lamps in less than like 20 minutes...
