My Truck Cuts Out!
My truck cuts out! How do you fix it? Just driving it will cut out for like .5 seconds and then be fine. How do you fix this?
We'd like to help you Justin, but you gave us almost no data, and since your sig is not filled out, we have no idea what your driving.(year, engine, etc.....)
DEWFPO
Ha, Oh yea. Its a CC 2002 8.1 2500HD.....
A rough guess would be the crankshaft position sensor. Suggest you run a search on it and see what others have to say about it.
DEWFPO
Either crank sensor(Most likely) like stated or fuel pump. I just went throught this nonsense a few weeks ago. Turned out in my case both were bad.
Could this be fuel related? The first day I had it, it happenend 4 times. Same day I put some lucas fuel cleaner in it and it hasnt done it since.....
Im getting no engine codes, but i am getting 2 tranny codes. P1779 - Engine Torque Delivered to TCM signal & P0700 - Transmission Control System malfunction. Anyone know where to get a used TCM for the allison and how you change it if thats the case?
It could possibly be the fuel filter with 111,000 it could possible be the problem. When was the last time you have changed it? You might also try Sea Foam. Do a search on the forum on how to do it.
Does the truck only cut out in gear or does it do this also in park or neutral?
Yea, I want to but I dont really have a place to do it right now. I want to run seafoam too.
Well, so far only in D. I dont idle enough to find out if it does it in park.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 634 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
