I Got An Allison Tranny Problem....or Maybe Something Else.
justin95
Ok, I just got the truck and it has 111,000 miles on it. Here is what has happend so far.
* At highway speeds it will cut out for ~ .5 seconds and the rpms will plumet then go back to normal driving.
* At low speeds in traffic it will completly cut of and I will have to restart the truck.
* I noticed today when I was using the cruise control when it cut out on the hwy after I tried to use the cruise again and it wouldnt come on, but later after the truck was turned off then back on the cruise was working again. Weird.
* I just went and got my codes checked just incase because there are none on and there were 2 for the tranny. Which include:
1. P1779 - Engine Torque Delivered to TCM signal
2. P0700 - Transmission Control System Malfunction
What does this mean and how can the engine cut out if they dont have the same computer? Could I just have engine problem that doesnt show up in the codes and the tranny codes are just thier no being the problem? Oh and this has happend on monday(4 times) & today(~4 times).
It sounds like it (The Transmission) is kicking into limp mode. It does this to protect itself from further damage. I doubt it's the engine, you probably have a clutch pack that's burned up. Don't panic, you can buy a Suncoast kit that will make it a much stonger transmission. I would conact Mike L. at Inglewood Transmission in Southern California or Eric at Merchant Auto in Michigan. They both have web sites you can check out. You might want to talk to the person you bought it from, I'll bet he had a programmer and ran it hard, once it starts limping it only gets progressively worse. I would be willing to bet that it started limping on him and that's why he sold it. Good Luck.
It could possibly be the sender coming from the crank shaft sensor. My 2500HD did something similair and then would stall and needed to restart it. Not certain but well worth a try.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
