Bad Oil Filter
I was changing my oil today and ended up with a oil filter with a bad seal, If I take it off to put a new one on anybody know how much oil i'll loose? 07 Sierra 5.3L
Only the oil that is in the filter and immediately above it where the filter mounts, so less than 1/2 quart.
Yeah... once you replace it all you need to do is check and add as needed to show the right level on the dipstick. Then, start and run it for a few minutes. Once it has circulated the oil well, check and make sure your level is good.
No worries. Doesn't happen very often but anything can fail. :sigh:
