03 S-10 Will Not Switch Into 4wd
amlumber
My father-in-law, cannot get his S-10 to switch into four-wheel drive. We checked the fuses, with no luck... Anyone have ideas. I don't want to take it to the dealer, unless absolutly nessary. Thanks, for your input.
If it is push button, check the transfer case motor. I'm not sure where they are on the little transfer cases but there is only a few bolts/screws holding it on. You can pick them up usually for under $100.
Whoa, its been a while since i bought one, one for your truck from advance auto is at least $200 here is a link so you can get an idea of what it looks like, i'd check that puppy out and make sure before i'd buy one. In my ranger i replaced it twice and i changed one in a 97 k1500 for a friend. good luck, hopefully you don't need to buy a new one.
http://www.partsamerica.com/ProductDetail....672&PTSet=A
Ok, how about this....
It is push button. Disconnected the battery, after 15 min, reconnected it. Now everything works fine. Do the computers F up every now and then?
Who knows but thats much better than having to replace parts and trying to find the problem! If only all problems were that easy.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
