07 Sierra Block Heater Cord
Where do you guys have your block heater cord fed through? I just plugged my truck in for the first time, and the cord isn't long enough to feed up to my hood.
Thanks.
i still can't find the d**n thing!!
Open your hood, stand in front of the driver's side headlight and look down behind the fan. It's coiled up with a cover over the plug right down by a couple of other cables. It has a zip tie around it.
I don't know about anyone else but my block heater cord was hooked on the bar right next to windshield wash. Its long enough to reach out between the grill and driverside headlight.
Not sure if mine's even worth digging it out and plugging it in. The owners manual says it has a thermostatic switch in the plug that shuts it off above -12C (10deg F). It has to be pretty cold to get below that.
I recently was wondering the same thing, and got some great ideas in my post. I put the link below, but it might not work. If not, just search for my topic. Down by the tow hook is working great for me!
Block heater route?
i'll check again tonight, how far down from the top of the hood to the location?
i was crawlin gall over my engine bay lookin for the stupid thing, i can't find it haha
Reach your arm straight down beside the washer fluid tank. You'll feel a cable. Look around right there, it's coiled up neatly with a cover over the plug. If it's not there, you might want to ask the dealership if they forgot to put it in. That's always a possibility too.
Well, I took a look today (now that there's some light), and I dropped the cord straight down, then fed it up in front of the radiator and fed it out through the grill. I have the cap wrapped around one of the vertical slats on the grill to hold the cord in place.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
