Brake Lines
macky
Hi
This is my first post and I sure hope someone can help me. I have a 1999 GMC Sierra extended cab 4.8 engine. I had a brake line let go near what I guess is the BPMV ? it's the block where all the lines go for the ABS. Hear is where it gets bad I found the line I needed to change had to unscrew all the lines to get to the one that was broke I labeled all lines so I would know where they went and as I moved the broken line away three of the lines all broke up on the frame and now I can't tell what line goes where I have called all local dealers and everyone I know that works on trucks and nothing. The only thing I know for sure is that the line going to the back brakes is right now where do the other four lines go. Any help would be appreciated because even if I had another truck to look at the line are so screwed up you cant follow them back to the front of the truck to see what is what.
Thank you.
Macky
