dhale16 Posted December 7, 2007 Posted December 7, 2007 I was wondering if someone could tell me how i can tell for sure if i have an exhaust leak or just that annoying 6.0 ticking so many people talk about. my truck is a 05 2500 HD
justin95 Posted December 8, 2007 Posted December 8, 2007 Its most likely piston slap. This webiste should tell you anything you need to know & it has sound clips. pistonslap.com
08 Sierra Z71 Posted December 8, 2007 Posted December 8, 2007 I was wondering if someone could tell me how i can tell for sure if i have an exhaust leak or just that annoying 6.0 ticking so many people talk about. my truck is a 05 2500 HD I have a new 08 Sierra with the 6.0. After several weeks of driving, the engine started ticking. The ticking noise was coming from the left side of the enginge, and could be heard even better near the left front wheel well. About the same time I noticed the engine ticking, my engine light came on. I contactacted Onstar and they diagnosed the problem as bank one and bank two heated oxygen sensers. By the time I took the truck in for repair, the engine light was out. Service Dept. said that they couldn't use OnStar's diagnoses and that there were no codes stored on the truck's computer. Turned out to be a gasket leak on the exhaust system. I was told the gasket was located between the "Y" flange and the catalytic converter. Not sure if the leak had anything to do with the engine light, but it hasn't been back in since they repaired the leak.
dhale16 Posted December 9, 2007 Author Posted December 9, 2007 i checked that web site out and that truck sounded like a diesel. My truck is not nearly that bad . my truck sounds like something totally different it's a real light tick. thanks for the info, very interesting web site.
ryank1 Posted December 9, 2007 Posted December 9, 2007 That is a very misleading web site that is sponsered by lawyers. The piston slap issue in the 3100 series motors is very different. The cylinder walls in these motors would score to the point were you could feel the scoring. The piston slap on the LSX engines, per a GM engineer that I spoke with and also from personal experiance seeing many engines torn down, is the fact that the skirt has been almost completly eliminated from the piston. This was done to save rotating mass weight and increase efficiency as well as performance. I do mechanical inspections for a living and I can honestly say that the LSX series of engines is one of the most reliable that I have seen. The noise in these engines is made worse by carbon build up on the piston tops, which effectively raises the compression ratio of the engine and causes the piston to rock more. I have been sucessful in quieting many of these engines down, simply by completing a decarb on the engine. I have seen very few failures in this line of engines compared to others. I have seen high milage examples torn down and have never seen scoring in the cylinder walls to the point where it can be felt like in the 3100 engines.
justin95 Posted December 9, 2007 Posted December 9, 2007 Yea, Just have your exhaust looked over and if there are no leaks then you most likely know your problem.....Like every vehicle Ive owned and heard have it, but ofcourse some some are worse then others like my 6.0 had it bad, but my 8.1 doesnt.
