Wow What A Difference
I just installed the headers, intake, and Custom 3 inch mandrel bent exhaust, and noticed a big difference with the butt dyno. It pulls hard thru the gears but wish it was a 6speed. Next mods to come custom tune, heads milled to raise compression to 10.5:1 port matching intake/exhaust, 6speed conversion, and a turbo setup.
Hopefully looking at 500RWHP when done with only 8PSI.
Why mill the heads and then add a turbo? Why don't you keep the compression down low and then raise boost more?
ditto. High compression is accomplished with higher initial intake pressure OR tighter squeeze.
I said it wrong. I should have said that i will be milling a second set of heads, and use them untill i get the turbo setup.
5.3L should easily put 500HP @ the RW with these mods.....I think the turbo will put more (hope you got an extra set of tires to smoke) :cheers:
Wow! Will a second set of heads be worth that much trouble? The 5.3L is already 9.9:1.
I am not against getting the most out of a stock engine in a truck. But wouldn't it make more sense to go to this extent in a F-body car or Mustang or any car that is designed for it instead of a nearly 6000lb brick?
Even if you get 500 RWHP, you will still lose to just about any V8 car with similar mods.
Just my .02
will either one of those be able to pull a load? hmmm, just a thought....though I have no idea if the truck would be used to pull anything with these mods.
Making a truck fast is more challenging. Anyone can make an Fbody or a Mustang fast. Plus with a truck you can drive thru deep snow, tow stuff, haul a couch in the bed, all kinds of stuff. It's an all in 1 package!!! Besides even if you do put similar mods in one of those cars, there's always someone out there with more mods, whose faster.
Freak did you go with Pacesetters?? What would be much easier than a 6l90 swap would be a T56 swap.
Can't argue that. But I think it'd be much more fun/satisfying getting the most possible performance out of the same mods. The "fun factor" between a 500RWHP car vs a 500RWHP "Brick" would be no comparison IMO.
d**n, I wish my brother-in-law had never let me drive his C6 Vette.
Not everyone can make a mustang fast. Ford has been trying for 40 years and haven't done it yet.
They could if they really wanted to.
And what about the Mach 1...1970-71 I believe? Wasn't a Ford guy in High school, but a friend of my brother's had a Boss 302 which was pretty fast.
