punmax Posted December 8, 2007 Posted December 8, 2007 I want to get the Edge Evo. But, I have some concerns about it. Does it void the warranty on the truck if GM finds out about the tune? Can I take it off easily before going to the dealership? Pulling the plug out and back in, will it mess it up?
shedberg Posted December 8, 2007 Posted December 8, 2007 The Evo owner's manual says to reset it back to stock before taking it to the dealer. Also, you don't have to leave it hooked up all the time, you can take it out whenever you want.
VMax2007 Posted December 8, 2007 Posted December 8, 2007 I have one, and I had my truck back to the dealer for the oil leak. They replaced the Crank Position Sensor, so I am assuming they had to re-flash my ECM and or TCM. I set it back to stock beforehand and they never said a word. This is one reason I chose the Edge, to be able to go back to stock for dealer visits. I may upgrade to a custom tune someday, but for now, the Edge will suffice. It works great.
punmax Posted December 9, 2007 Author Posted December 9, 2007 I have one, and I had my truck back to the dealer for the oil leak. They replaced the Crank Position Sensor, so I am assuming they had to re-flash my ECM and or TCM. I set it back to stock beforehand and they never said a word. This is one reason I chose the Edge, to be able to go back to stock for dealer visits. I may upgrade to a custom tune someday, but for now, the Edge will suffice. It works great. Can you post some pics of your Edge? The wiring, pod, etc. Also what is the pod held with?
VMax2007 Posted December 10, 2007 Posted December 10, 2007 I have one, and I had my truck back to the dealer for the oil leak. They replaced the Crank Position Sensor, so I am assuming they had to re-flash my ECM and or TCM. I set it back to stock beforehand and they never said a word. This is one reason I chose the Edge, to be able to go back to stock for dealer visits. I may upgrade to a custom tune someday, but for now, the Edge will suffice. It works great. Can you post some pics of your Edge? The wiring, pod, etc. Also what is the pod held with? Do a search in the "Performance engine tuning" section under "Technical" category on main page. I as well as others have posted many pics and write-ups on the Edge Evo. Type in "Edge evolution" in the search box.
