Vibration When Accelerating
When traveling down the road about 40mph or so.....if you gas it without kicking it down. there is a vibration and noise in the dash. I think it is the dash vibrating but has anyone experienced similar noise...it maybe the intake also....the intake is not very loud but when you give it some gas it makes the noise...when it kicks down...smooth as silk...any ideas???
I swear at times I get the same "rumble strip" feeling that people are complaining about in the new tundra. I've never felt that before in any vehicle, but I think I get it from time to time. It's a slight vibration, and they say it's from the torque converter. I'm gonna keep driving it, because if I bring it in, they will just say can't duplicate problem. Mine does not vibrate in the dash, but feels like it's in the tranny.
I wonder what it could be from...maybe the intake noise causes the vibration?
Mine makes the same noise I think its either the upper dash or the pillar on the driver side.When I put pressure on them it goes away I'll take it in soon and let try to fix it or I'll do if they can't.It did it with the stock air box&exhaust and with the gm cold air intake&corsa exhaust it still does it.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
