Tire Diameter Vs. Mph
Since this seems to be a wealth of knowledge, how much is the speedometer going to be off (and which way) when I change back to the original tires for the winter? I have P275/55 20's on there now. I have the 18" wheels and tires that the truck came with (not sure the size but the Z-71 tires).
Does anyone know how much of a difference this will make on the speedometer? I know the dealer can recalibrate it but would be nice to know how much difference.
If no respose, I will try to measure them and calculate it out.
Thanks.
Lance
Thanks.
Lance
You really need the tire size in addition to the rim size for both before you can do any relevant calculations. You could to the standard draw a line on the tire and driveway and rotate 1 revolution and measure the distance between.
HERE is a tire calculator you can use when you get the correct sizes.
Bish - Thanks again :M16: . From my search.....and your link... It shows 0.7 mph difference when the tires are changed. 20's read 60mph - 18's actually be 59.3mph.
That is not compensating for tire pressure difference and thermal expansion of the rubber :crackup: .
Here is a site that will show the actual MPH. Use the first link first to get the tire height then the second link to see actual MPH. You put in diameter of tires then a MPH and then it will automatically show you the actual speed.
Tire Height and Speedometer
WOW... that's not even enough to worry about. Happy swapping.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
